2 weeks ago
I am getting a low battery warning on one of 5 units in my house. The app says all batteries are good. All batteries are the same age. All are the expensive required batteries and all purchased at the same time and from the same package. This is the same unit that went off and made that hideous noise despite new batteries and I have been woken up twice tonight with a low battery warning. Am very aggravated (and sleep deprived).
a week ago
Hi Meg3,
Thank you for posting. I'm sorry that your Nest Lock shows the notification of low battery; this could be annoying, especially at night. Help's here.
Sometimes the Nest Lock needs to change the battery life, even though you purchased it all at the same time. Not every battery holds the same power or charge.
There is a good article on how to check and change your Nest x Yale Lock batteries.
Let me know if you need more assistance.
Byron
