2 Battery Nest Doorbell
Premium__Zocker
Hello, I'm considering buying a nest battery doorbell. However, since I live in an apartment building, I wonder if I can connect 2 doorbells at the same time?
A google search only showed me results for the wired doorbell.
Thanks
You can hook up more than 1 Nest Doorbell up, but you will need the appropriate connections to power them. If you live in an apartment building, I would suggest checking with them to see if you can actually install one there first. Sometimes some complex's will have rules about smart doorbells, etc.
6 REPLIES 6
I apologize for my late response and thank you for all of your patience while waiting for a reply. I definitely understand how frustrating your situation must be, and I wanted to make sure that your concern was acknowledged. Do you still need help with this issue?
Hello, thanks for your answer.
Yes I would still need help with that(:
Premium__Zocker
Perfect, thanks a lot for your help!
Appreciate the help, Brad.
@Premium__Zocker, do you still need help with your Nest Hello? Let us know, we're here to help.
Archie
aatienza
Hey Premium__Zocker,
I'd like to bump in here to make sure that you've seen our response.
Have a great day.
Archie
