2nd generation door bell chime
AJaramillo19
My chime connector isn't working it vibrates my door bell box it will chime and then chime again after 3 minutes have also changed the transformer
EdmondB
Hello Ajaramillo19,
I’m sorry to hear you’re having trouble with this. No worries; we'll check this out. Just a few questions: When you remove the chime connector and test the doorbell, does it ring? How much voltage does your transformer have? Are you getting at least 16–24 volts when you test the two wires on the Nest doorbell?
Edmond
