Another Nest Aware Plus Upgrade Problem
vinnythestick
After buying two Nest Cams and having them installed, I was subscribed to the trial nest aware, which was automatically billed after 30 days and I pay annually because I have the disposable income, and its cheaper that way, but now that I want to check 24/7 recorded history it turns out I only subscribed to Nest Aware and not Nest Aware Plus, and I cant for the life of me figure out how to upgrade my subscription. I just read a bunch of similar complaints stretching back to April of this year, so I know there's not a single thing that one of your "community support specialists" is going to be able to do to help me. It's so stupid that I am right now trying to find a way to give Google more money, but I cant do it because Google is a poorly focused company that is heading the way of Microsoft, and is failing at competing with Apple. I think it's about time I throw in the towel and switch to the premium phone company.
2 REPLIES 2
David_K
You should be able to upgrade to Nest Aware Plus from your subscriptions page on the Google Store:
https://store.google.com/subscriptions
If you select your subscription, do you not see such an option?
@vinnythestick
If you find that you cannot upgrade your subscription online (this post says there is no way to do it online: https://www.googlenestcommunity.com/t5/Nest-Aware/No-option-to-upgrade-to-nest-aware-plus/td-p/23227...), you could try the "Contact us" option under "Nest Aware Premier Care" on the page below to "Get 24/7 access to Nest Aware Experts on the Nest Customer Care team. They’re available to answer questions, help you access features, and manage your subscription.":
https://support.google.com/googlenest/answer/9233159
