Battery doorbell notifications
LGB
I just installed the new Nest battery doorbell and camera; all works well; one question: how do I keep the doorbell notification on my iPhone while switching off all other notifications ? I would have expected a separate function for this in the notification settings; i don’t want all notifications when people walk by but i do want a notification when somebody rings the bell. Any suggestions?
11 REPLIES 11
Summoner
Try this
Home App -> Doorbell -> Gear icon (settings) -> Notifications -> your notifications under zones -> disable all notifications
Kroezer95
I think your misunderstanding the OP. He/she only want to receive a doorbell button press(call) notification.(Ring has this feature and the notification also has a bell icon)  Unfortunately, the new NEST doorbell (battery) does not have a call button notification setting at this time.  I’m with you though…IT SHOULD.  For instance, I don’t want motion notifications while home unless someone pushes the button.
LGB
Agree. Thanks for the feedback. I now only managed to switch off all notifications except when someone rings the doorbell; but … i will only get a banner on my phone, nothing else, which isn’t very handy; I still would vote for a clear option in the settings where I would be able to activate only the doorbell notification on my phone incl sound
Kroezer95
Ok, you stumped me…how did you turn off all notifications except the doorbell call button notification?  When disabling ‘all notifications’, do you still get a doorbell call notification?
LGB
What i did is in Settings, Notifications, switch on push notification and then switch off all the options below. The result is that you won’t get the alerts from the camera but you do get the alert (notification banner) when someone rings the bell.
The odd thing is that my Google Nest Hub does give a proper alarm incl sound when somebody rings the doorbell, so it should be possible on the phone also. It would be great if Google would add this option (/ this feature) for phones also.
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I am terribly sorry to hear that you have had such a hard time with this! I would love to look into this issue further and help find a solution for you. I have some questions I’d like to ask you first:
  • Do you still need help with this issue?
  • What troubleshooting steps have you done thus far?
  • Have you tried to restart your device if you haven’t already?
LGB
thanks Brad
Yes, I’ve restarted the device
Yes, for now it ‘works’ but it is not ideal; I am still convinced that a feature / option could (/ should) be added that enables the battery bell notification on your phone incl sound alert, irrespective/ independent of the other notification settings.
Or maybe I miss something in the configuration and settings of the device.
Thanks for the support
Billy1948
I just bought the nest doorbell and nest hub 2nd generation and no matter what I try it will not notify me or turn on camera on my nest hub I would like to see who is outside and hear a chime on my google nest hub but when I go into nest app it doesn't show any of my nest products the googel home app does and when I try to have Google home work with nest app when I search nest in home app it doesn't show nest app in the list I am stumped on what to do...
GarrettDS
Hi there Billy1948,
So sorry to hear about the issues that you're having with trying to figure out your doorbell and the notifications on your hub, I can understand that it can be confusing, but I'm happy to help.
Unfortunately, it is not possible to get doorbell notifications on your Nest Hub 2nd generation. Feedback like this helps us constantly improve our products and services by knowing what we are doing right and what we can work on. I'm happy to take this and send it to our team so that they can look into applying this in the future.
Don't hesitate to reach out if you have any more questions, comments, or concerns.
Garrett DS
GarrettDS
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
