09-09-2022 11:25 AM
Hi my doorbell sent error messages while it was raining saying it was experiencing extreme weather.
(The weather was fairly typical).
Since then the doorbell is offline and I can’t reconnect it.
My other Google devices are all online, I do not have problems with WiFi.
I have reset WiFi. I still can’t get the device online.
I have pressed the reset button, the white light came on briefly, but still offline.
The doorbell is fully charged, It feels warm to touch even though the environment temperature is 17 degrees centigrade.
Can anyone help?
09-13-2022 11:29 AM
I am terribly sorry to hear that you're having this issue with your Nest camera! I'm sure it's frustrating, but I'm happy to look into this and see how we can help out. The first troubleshooting step that I'd recommend would be to restart your device. By doing this, it should keep all your settings, and reconnect it to the same Wi-Fi network. This is helpful if it ever freezes, has connection problems, or isn't working normally.
09-16-2022 03:18 PM
I appreciate the help, Brad.
Archie
09-17-2022 09:20 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
09-18-2022 09:56 AM
Hi I did all the troubleshooting steps and nothing worked. I have got a replacement and hope the new one lasts longer. Thanks.
09-18-2022 02:59 PM
Hi LibbyO,
Great, thanks for letting us know! Give us a shout if you have any questions.
09-21-2022 05:10 PM
Checking back in — how's it going with your Nest Doorbell (battery)? Still need our help?
09-22-2022 07:05 PM
I appreciate the help, JT.
Archie
