12-15-2023 06:16 PM
Trying to set for google doorbell battery.......getting caught in loop between HOME and NEST. seems others had this issue before and no solution was posted. Twice got yo point of trying to connect but the srvices do not see the doorbell.....HELP
12-15-2023 07:13 PM
I'm not sure what problem you're having. All of the newer Google Nest cameras and doorbells released starting in Sept. 2021--including the battery doorbell--get installed only in the Google Home app, and do NOT work in the Google Nest app.
12-16-2023 05:47 AM
There is some kind of glitchy loop. I start in google home app, add device, doorbell, it tries to connect my phone to doorbell via bluetooth, cant, then flips to nest, and when add doorbell is selected it says needs to be installed via home...and round and round we go
12-16-2023 07:56 AM
You could try deleting and reinstalling the Google Home app.
If that doesn't work, you could check this troubleshooting page:
https://support.google.com/googlenest/answer/9240048
If that doesn't help, you could try contacting Support, using the link and instructions in this post:
12-20-2023 02:34 PM
@Michben, thanks for reaching out here in the Community. Aside from the steps shared above, please make sure that your Nest Doorbell has a blue light pulsing indicating that it's ready to connect. We would also recommend you to reset it to factory default.
To reset:
Give these steps a try:
