04-23-2023 08:29 PM
I have had these cameras for about a year without problems. This week I tried charging 2 cameras on 2 original charging cables and both are suddenly having issues. After fiddling with the cables they finally started charging very slowly. They have both been plugged in for 3 days and one has charged to 23% and the other 24%. The white light is on but there is no further progress.
Is there a fix other than keeping the cameras plugged in?
04-24-2023 03:33 AM
Hi im no expert just a user.. Just wondering how cold it is where you are as thats the only thing i can think may be affecting them other than faulty cables... They wont charge in really cold temperatures
04-24-2023 02:04 PM
Thanks for the note! cold temperatures are not a factor.
Also, I unplugged them, cleaned the charging port area and put them back on to charge. 5 hours later one went from 24% to 16% charge and the other went down 1%. Very strange.
04-25-2023 04:36 AM
Strange indeed... Im sorry i cant be of help... I gather youve tried factory reset?
05-12-2023 02:01 PM
Hi Jzb,
I know it’s been a while, and I’m sorry to hear about the situation. Let’s sort this out.
A few questions: are you using the provided cable and adapter when charging your devices? Also, have you checked for any possible dirt build up on the pogo connector? If not, check for it and use a clean, dry cotton swab to clean it off.
I’ll look forward to your response.
Thanks for your help, @Anonymous.
05-15-2023 07:56 PM
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
05-16-2023 08:24 PM
Hello there,
Juni
