08-16-2022 02:02 PM
Hi
id like to know where Google gets its 1.5 month as a minimum battery life for the outdoor camera ??
Mine is newly bought and needs to be charged once a week . I have all the battery saving mechanisms turned on … and fully charge it for 5 hours as requested and yet only get the one week barely ??
Any other members have this problem .
08-16-2022 02:40 PM
There are MANY postings in this forum about needing to charge the Google Nest Camera (Battery) far more often than implied in the marketing literature. I'm thankful we bought the optional power cable and have ours plugged in all the time (since Sept. 2021) so we don't have to deal with frequent charging (or various other charging issues).
08-16-2022 02:44 PM
08-23-2022 11:50 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I'm terribly sorry to hear that you're having these troubles. I understand how upsetting this could be, but I'm happy to assist you with this obstacle. You can find a ton of helpful information on charging in this article. I hope it helps you out with charging troubles with your battery.
08-23-2022 01:10 PM
08-17-2022 04:09 PM
I'm actually going through the same issue, so far only response is extreme temperature impacts battery life. I can somewhat believe this since my backyard camera doesn't have a problem and the sun sets on that side. Currently on replacement camera #2 and ongoing issue on driveway where the sun rises and Florida USA summers are hot.
Hope this helps
08-23-2022 01:12 PM
I live in quite a temperature stable environment neither too hot nor too cold :)but thank you … my main gripe is that I feel it’s very misleading publishing these battery times … it has excellent resolution / picture quality
08-31-2022 11:21 PM - edited 08-31-2022 11:24 PM
Thanks for your help here, MplsCustomer and EcuazRey.
Chris1414, thanks for sharing that I can understand where you're coming from. Let's get this sorted — a few questions: where is your Nest Doorbell (battery) located? Was there any power outage recently? Also, do you keep it connected to the charger until it's fully charged?
Going over the steps here might help:
Let me know how it goes.
09-01-2022 07:56 AM
The issue here is the battery life for the Google Nest Camera (Battery), but your answer refers to the Google Nest Doorbell (Battery).
09-01-2022 09:09 AM
Adding to the original concern, now the camera battery is charging slowly. It was mounted outside and while charging inside it's saying extreme temperature and both camera/charger are warm.
09-01-2022 09:42 AM
I don't know why your camera would report extreme temperatures while charging it indoors, unless it previously got overheated while outside.
We have had a Google Nest Camera (Battery) since Sept. 2021, plugged in all the time with the optional power cable, and it has been "Live" at all times and has never reported extreme temperatures in Minnesota winter temperatures as cold as 20 degrees below zero Fahrenheit and Minnesota summer temperatures as high as 100 degrees Fahrenheit. The camera is installed under an outdoor shade. Our older Google Nest outdoor cameras are either under an overhang or under a shade; it seems to make a difference, since none of them malfunction due to temperature.
09-01-2022 10:14 AM
Yeah it's not wired outside so my guess it's that since the sun rises on drive way and is maintained wireless.
09-07-2022 11:19 AM
Just checking in to see how the conversation is going, as there's been a lapse in activity on this thread.
09-07-2022 11:35 AM
Firstly it’s a nest camera , secondly no there was no power outage recently and thirdly are you seriously asking me if I fully charge the camera battery prior to use ….. of course I do 🙄….
09-09-2022 08:50 AM
