Can I change Nest doorbell battery wired or not wired options change after installing
Cifen
I installed nest doorbell battery with wired options. Then I change mind to not wired. The doorbell seems stay offline with unmount status.
I seem not to be able to find a setting to allow me change wired to battery without reinstalling it. Please advise thanks your help in advance
2 REPLIES 2
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I am terribly sorry to hear that you have had such a hard time with this! I would love to look into this issue further and help find a solution for you. First off, I have some questions I’d like to ask you.
  • Do you still need help with this issue?
  • What troubleshooting steps have you done thus far?
  • Have you tried to restart your device if you haven’t already?
  • If the restart didn’t work, have you tried to do a Factory Reset? This would be a last resort option, but would clear out issues and the device would essentially be ‘brand new’
GarrettDS
Have a great day,
Garrett DS
