Can I use Nest camera as standard IP cameras?
Wadera
Nest cameras are great with all AI capabilities related to Nest Aware, but... In case if I want to build my own recording environments in feature with Google AI, Tensor Cores etc. Or just simply change it to old fashioned IP Cameras - Can I connect to Nest Cameras with any old fashion softwares and start recording?
6 REPLIES 6
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be. I just wanted to make sure that your issue is addressed.
  • Do you still need help with this issue?
  • This would also depend on which software you want to try connecting it too. I would generally suggest only using the provided software and app for the device.
Wadera
Hi, sorry for slow responce - busy week.
Yes, I still didn't find an answer if Nest cameras can be used only with Nest / Google softwares or if I want to - I can use them as standard IP cameras and connect it to any other softwares or not?
@Wadera
The answer would be no, you are not able to do what you request. These are made to function in a normal Nest/Google Home environment.
Jeff
Hi, Wadera.
I just wanted to jump in real fast to see if you saw Brad's last reply and to see if you still needed some help on this or if you were able to get it sorted out. If you are still needing some help, just let us know and we'll be happy to continue helping.
Thanks.
Jeff
Hi, everyone.
Thanks
