01-22-2022 05:41 AM
there already is a thread related to this item,
Can't connect to assisting device
but i my case the answer was just a little bit different
the issue is..
I bought a Nest cam (battery) duo pack . After installing the first Nest cam the setup of the second cam wouldn't pair. Google Home's respond was : Can't connect to assisting device.
After hours and hours of trouble shooting i noticed a part of the septup instructions that said 'The LED light on the device has to be blue ( ready for pairing) .
The LED light on my second cam was 'Green' or somtimes white , depening if it was connected to an adaptor Seems as if the Nest cam was already sort of paired ( not correct/fully) .
To solve this issue i did a full factory reset (reset button 10 seconds , yellow light blinks 4 times and the 2 more seconds)
The Nest Cam fully reboots, White light > then a blue light. Connected the device to a 220v USB adaptor (instead of a usb port of a device)
while the blue light was on , the setup procedure went smooth ( i did start with the troubling device this time and followed with the first cam i earliers disconneted as adviced in the other post.
04-28-2022 11:17 AM
Thanks for visiting the Community. Since this thread hasn't had activity in a while, we're going to close it to keep content fresh.
We hope you were able to get the help you need, but if you're still having trouble, please feel free to submit another post, and provide as many details as possible so that others can lend a hand. Hope this helps!
