Can't get doorbell off to recharge battery
Ronas
I can't get the doorbell off the bracket. I have the tool and it says to insert it into the hole in the top of the doorbell but there is no hole in the top.  There is one in the bottom of the doorbell but it's more like a small slit, not a hole.  I don't understand how this can happen.
2 REPLIES 2
@Ronas
In the first video on the page below, starting at about 3:20, you'll find instructions on mounting and dismounting the battery doorbell. It's a small slit, not a round hole. If yours is on the bottom, is it possible your doorbell is mounted upside down?
https://support.google.com/googlenest/answer/10732535
Lance_L
Hey everyone,
@Ronas, thanks for posting in the Community. I’m sorry to hear that you’re having trouble with the Nest doorbell. I wanted to check if you still need help with this. Have you seen MplsCustomer’s response above? If yes, how was it?
You can also check out this guide to learn how to remove a Nest camera or doorbell from its stand or mount.
Lance
