08-23-2023 07:38 PM
Hello community
I changed my Wi-Fi network password last week. My cam was booted off showing offline. Read instructions that led me down the path of removing the cam from Google home to reset up.
followed all instructions multiple times.
restarted router
restarted iPhone and iPad- tried both
reset the cam
tried to add at least 5 or more times, resetting each time
the cam has a white light
occasionally makes a sound
always ends in ‘something is wrong’ message
never had any issues for 3 plus years until i changed my Wi-Fi password
Ideas?
08-24-2023 10:00 AM
Unfortunately, Google Nest does not make it easy to change Wi-Fi settings. That's why their first recommendation when getting a new router/modem is to set your network name (SSID) and password to the same values used on your old router/modem. If you can't do that, then with cameras in the Google Home app, you are supposed to remove the camera from the Google Home app while you are still on the old Wi-Fi and have contact with the camera:
https://support.google.com/googlenest/answer/9223711
If you don't do that, even a factory reset doesn't fix things. When you did the factory reset, did you press and hold the factory reset button until, at 10 seconds the status light blinked yellow 4 times and you heard a countdown tone, followed at 12 seconds with a steady, solid yellow light while the camera resets and you hear a confirmation tone?
If you need to contact Support, you can use the link and instructions in this post; depending on the time of day and your locale, you may get phone callback, chat, or email options:
08-26-2023 08:29 AM
Thank you! I've done all of those things. Wondering if my camera is just broken-maybe a coincidence. I am taking to best buy today for a tech support. Maybe they will just replace it.
08-26-2023 04:40 PM
@Nursehgh, thanks for reaching out to us, and I'm sorry to hear about the situation. I want to check if you are still in need of any help. If so, please answer the following:
I appreciate your help, @MplsCustomer.
