12-22-2024 04:06 PM
I have a new 5G modem with new WiFi settings.
I've linked my Google Nest Hub Max and a couple of lights to the new WiFi, BUT I cannot update my 2 Nest Cams to it.
Your instructions tell me to:
Open Google Home > Tap & hold Device Tile > Tap Settings > Device Information > Tap WiFi > Forget Network
But WiFi is not shown in Device Information, and I can't find it anywhere else in order to change it.
I don't doubt it's my fault, but I'd sure like some help that works. Please…
12-22-2024 04:23 PM - edited 12-22-2024 04:30 PM
You mightt be referencing some instructions for Google Nest's Wi-Fi devices. Google Nest does not make it easy to change Wi-Fi settings; with the 2nd gen cameras, you usually have to do a factory reset, especially if you did NOT remove the cameras from the Google Home app while still on the old Wi-Fi network.
See this Help topic on the subject:
12-25-2024 11:53 AM
Thank you. I did a factory reset and started again and that worked.
