03-15-2024 02:35 AM
Hi, I have a Google doorbell (battery), all set up. On my own so difficult to test. I was away from house but luckily on my phone doing something else when I saw a notification from my doorbell (didn't hear a beep or anything) someone had pressed it. I quickly opened the Google Home app and was able to speak to the postman.
I've since found the doorbell pressed sound option in App Settings (phone is an Android Redmi Note 8 Pro) but not been able to change it for a louder sound. I've tested it at home and when I press it I think this quiet sound goes off on phone.
Can anyone explain to change to a loud music sound please.
03-17-2024 09:14 AM
Hi jettamc,
Thanks for reaching out to us. To change the alert sound for your Google doorbell (battery) to a louder sound, you can follow these steps:
Let us know how it goes.
03-18-2024 01:39 PM
Thanks for your suggestion. Have tried your it but there is no Doorbell pressed sound option under the Settings. I have attached a screenshot of what my Settings options are.
Sorry not sure how I attach a screenshot so I'm listing the options:-
General
. Device information
. Notifications
Device features
. Battery
. Events
. Doorbell
. Video
. Audio
That's all.
03-22-2024 10:06 AM
Hi I have found an option with similat title. It's in my phone settings, Apps option, Manage Apps option, then choosing the Home app, choosing the Notifications option which says yes, and the last option on this page is 'Doorbell press notifications'. When I choose that I have 5 ptions :-
Show notifications which is on
Allow floating notifications which is on
Sound which shows as set to 'Light steps'
Vibration which is on
On the Lock Screen set to 'Show all notifications and their contents.
If I choose Sound option it comes to a screen headed as a Ringtone tab and I then choose Pre-installed ringtones it shows a list of Ringtones, one of which is Light steps. I then choose another (loud music one) and press Apply next to it and a window pops up headed Select tone asking me to Select this ringtone - Cancel or OK. I choose OK it says 'applied successfully' and goes back to the 5 options screen mentioned above.
But the sound option still says 'Light steps' and when I come out back to my phone lock screen and try bell again its still the same quiet tone, so hasn't changed anything.
Is this the right options to change it and why isn't it saving the amended one i'm choosing?
04-01-2024 10:47 AM
Hi @jettamc,
Thanks for posting and I'm sorry for the delay. Help is here!
You can change the theme or set a different chime sound in the Home app doorbell settings. In addition to standard doorbell tones, seasonal doorbell themes are available around some holidays.
Here's how to do it:
For more information on Nest doorbell settings, you can refer to this article: Nest camera or doorbell settings.
Let me know how that works!
Jenniffer
04-02-2024 01:58 AM
Hi, thanks for all the help given. Just so you know I've now managed to change it through the Home app on my phone, 'Doorbell pressed sound '. As per my message above which says it didn't work, I kept trying it just by choosing a different ringtone and choosing Apply as above and eventually it accepted it and changed it. Didn't do anything different on all the times it didn't work so don't know why it suddenly decided to store the new one. Anyway it's solved thanks and I'm not touching it again.
Thanks for your assistance.
04-02-2024 10:10 AM
Hi @jettamc,
Great news! I'm glad to hear that you were able to change the tone.
If you have any more questions feel free to post again. We're here to help.
Jenniffer
