03-11-2024 05:06 PM
Has anyone found a suitable charger for this device’s supplied AC ‘indoor power adapter’ cables?
This charger may well be in US store - but links to AU Google products don’t work/product doesn’t exist.
The AC voltage for this purpose is stated to be 8-24V AC - which we have now tried with 3 chargers.
All are >15W stated as sufficient for Nest Cams - but DoorBell battery charger is not specified beyond ‘8-24V AC’ requirement. This device does not manage the battery charging when ‘plugged in’ - and you will be pulling it off the wall every few days - until this device comes along.
My own contribution - to date - is that the load varies significantly, so your AC charger should not be at 8V or 24V end of spec. 16V *almost* works - but you can tell the DoorBell isn’t charging in many scenarios - probably because the wattage and/or Amps must be stabilised to match DoorBell.
Maybe Google’s ‘indoor charger’ has 8-24V specified - at stabilised range, but I will fall pregnant before it’s available to AU customers, so very grateful for any tips on using US charger/what are its specs? Google does not provide this info. The ‘indoor charger’ for battery doorbell has a picture. But no specs.
Has anyone got one of these/tried to make doorbell camera last more than a day or two?
Such Win! Please do share!
Thanks-
Pat.
