09-01-2022 06:04 PM
I bought a home with doorbell and outdoor wired cameras. I cannot find the QR code and I cannot remove the camera from the base. Any help would be appreciated.
09-01-2022 06:32 PM
The QR code is printed on the bottom of our Google Nest Outdoor Cameras, as is the 6-character Setup Code if you're not able to scan the QR code. The camera is just attached with a magnet, so you should be able to pull it loose to at least read the Setup Code. The QR Code and Setup Code are printed on the back of our Google Nest Hello Doorbells.
Note that the previous owner/resident needs to remove the doorbell and cameras from their Google Nest app; see this help topic: https://support.google.com/googlenest/answer/11151047?hl=en#zippy=%2Cother-google-devices-set-up-in-....
If they fail to do that, even if you reset the devices, you'll get an error message saying the device is connected to another account: https://support.google.com/googlenest/answer/9249728?hl=en
09-06-2022 07:56 PM
Hey Tylertexas,
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue.
Archie
09-14-2022 07:09 PM
Hey Tylertexas,
Archie
09-15-2022 11:33 PM
Archie
