Data usage too high help?
BirdsEye
The camera is wired, so records continuously, and is on the lowest possible quality setting, but still uses 30 gb/day which is WAY too much, especially if you want to add additional cameras. What can be done about this?
I’ll add that the camera is in a location with low events. If it was located where it would encounter a lot of events I assume the usage would be the same or worse.
6 REPLIES 6
Cathal_S
Hi BirdsEye,
You can go into the camera settings / then 'Video' / then 'Video history' and set it to record just events and not 24/7 video history.
Cathal
janthadeus
Hi BirdsEye,
Checking in — I just wanted to make sure if you’ve seen Cathal_S’s response. Let me know if you need anything else.
I appreciate your help, Cathal_S.
Yes, I’ve seen the response and changed the setting but it only brings the usage down from approximately 10gb/day for 24/7 recording to 5gb/day for events only. Seems high for what you are getting. Too bad just can’t step down quality to not use so much data resources.
Juni
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
BirdsEye
No. I think I have enough information and understanding of the problem. Even on the lowest quality they use too much data over the original nest cameras. It’s holding me back from purchasing more. I pay for the 24/7 recording but unless I want to pay overages I have to set as event based only.
Juni
Hi BirdsEye,
As we got our resolution here, I'm going to mark this one as resolved. Please feel free to open up a new thread if you need assistance.
Juni
