Deactiveate ringing on several devices
SaPu78
Hi
How can I set up, that the doorbell only rings ob hub an/or selected devices? Each of our kids have mini speakers in their room and if somebody rings the bell while they are sleeping, they wake up and start to hate google mini speakers :-).
Txs for help
BG
Open the Google Home App. Scroll down until you find the device that you want to change and click/tap on it. Tap on the "settings" gear icon and under settings for that device, go to Notifications & digital Wellbeing setting. tap on Do Not Disturb, and enable (turn on) that setting. The doorbell will not ring on that device after that.
SaPu78
Thank you. Great as a temporery solution - but this also means, that group messages or "audio messages to all+ will be deactivated. Hope an update will bring more flexibility.
P.S Thanks for the help, @BG!
SaPu78
Thanky for asking. As a temporary solution this is fine. But it also means, that all notifications are turned off.  But better the having the kids woken up every time somebody rings the bell while they are sleeping.
  • Open the Google Home app
Google Home app
  • At the top right, tap your account.
  • Tap Feedback
and then
  • tap the type of device you'd like to submit feedback for.
  • To display available emails, in the "From:" section, tap the arrow on the right. Select your email address.
  • In the feedback summary, write a brief description of your issue.
  • Be sure to check the box for Screenshot and System logs.
  • To submit feedback, at the top right corner, tap Send
If you need anything else, please let me know.
