Door bell chine bussing
Buzzinghound
Why does my door bell chime goes ding and then buzzes for 8 seconds and then goes dong? I replaced transformer (16V 30va) and checked the wiring
EmptyNester
Silver Product Expert
There is a setting in the App that should let you fix this. Assuming you are using the NEST app go into it and look at the video from the doorbell.  Then hit setting (Gear) icon in the upper right corner.   Scroll all the way down until you see your doorbell icon and touch it.  Next scroll all the way down and you should see "CHIME DURATION".   There is a setting that says "Do you have an electronic Chime".  If it is off then turn it ON and then you can set the Chime Duration.  You should be able to set it to about 1 second and this should fix the problem.
Hope this helps
aatienza
Hey Buzzinghound,
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue.
I appreciate the help, EmptyNester.
Archie
SteveT1
We haven't heard any updates from you. Please let us know if you still need help as we will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Steve
