03-11-2023 12:05 PM
So our home lost power in a storm a few weeks back. Our doorbell, a 1st gen lost connectivity, but was still lit up. Today I finally pulled the device out of the bracket and tried a reset. Still no connection. So I factory reset it and went through the set up dialog. It seemed to be going well, it would let me select a wifi network but still wouldn't connect to the wifi.
So instead of pulling the doorbell off each time, I just took a picture of the info on the back of the doorbell. So I have been trying to get it back online by putting in the 6 digit code. But when it finally gets to the point where I'm supposed to select the proper serial number for my device, no serial numbers come up. It's like the doorbell is on but unable to connect to anything. Any ideas for troubleshooting?
03-11-2023 01:40 PM
Which doorbell do you actually have? You say you have a "1st gen", but the label on your post say "Nest Doorbell (wired Gen 2)". The problem with no serial number coming up can occur if you're trying to install a doorbell in the wrong app.
The Google Nest Hello Doorbell (sometimes called "1st gen") gets installed in the Google Nest app. The Google Nest Doorbell (Battery) and the 2nd Gen Google Nest Doorbell both get installed in the Google Home app.
03-15-2023 12:56 PM
Hello everybody,
@jrw8778, thanks for reaching out. How's it going with your Nest Doorbell? Were you able to set it up using the right app? What MplsCustomer has shared is right on the spot. In case you have an update, you know where to find us.
03-18-2023 03:59 PM
Hey jrw8778,
I wanted to follow up and see if you are still in need of any help. Please let me know if you are still having any concerns or questions from here, as I would be happy to take a closer look and assist you further.
03-19-2023 06:41 PM
Dan
