Doorbell battery wont reset
Mike2222
I've tried everything 5 times and this thing will not reset. Stuck in flashing white and nothing else.
rut9
I have the same issue.  Doorbell will not reset after 12+ seconds.  I cannot add to my home as it continues to error out each time.
I apologize for my late response and thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be, but I wanted to make sure that your issue was addressed. I would suggest if you can, let the battery die and then recharge it, try again to Factory Reset it. If you are still having this issue, I would suggest you seek out a replacement with Support. It may be faulty if it continues.
rut9
Thanks Brad.  It may take weeks for the battery to deplete...any way to speed up that process?
@rut9
Turn up all of your settings for notifications, sensitivity, etc. and with all of that on, you may get a lot more notifications and such, but it should drain quicker.
aatienza
Archie
