03-22-2022 04:43 PM
Actually my Nest Doorbell is wired. But that label was not an option.
I was checking my doorbell chime in order to connect the Chime Connector. My existing chime has only 2 wires.
The chime has three connection points labeled Rear Trans Front.
The wires for my existing doorbell chime are connected to the Rear and Front connection points. Neither wire is connected to Trans.
The Nest setup app does not provide any guidance on this wiring configuration. How should I connect the wires to the Chime Connector?
03-29-2022 03:53 PM
Thanks for reaching out. What type of chime are you using? Do you have a transformer?
You can check this article to Check Nest doorbell compatibility to learn more.
Steve
04-02-2022 11:30 PM
Jumping in to check if you've seen my response. If you have other questions and concerns. Feel free to let me know.
Steve
04-06-2022 03:38 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you're still in need of assistance, feel free to start a new thread and we'll be happy to help.
Steve
04-07-2022 03:41 PM
Hey Folks.
