Doorbell sound when charging
ali02155
My Nest Doorbell is currently charging and every 30 seconds to a minute is makes a sound ("ba-da-dup"). I don't remember this happening when I've charged it previously. Is there any way to turn the sound off? Thanks!
34 REPLIES 34
ali02155
Hi Brad,
yes please help.
thanks!
ali
Hey again,
Is it cold where you are located? Is it below 32 degrees fahrenheit?
ali02155
Hi Brad,
I am charging the doorbell inside my house, generally around 70 degrees.
Ali
Where’d you go Brad you wanted to help so bad and then vanished
SteveT1
Appreciate the help @Brad. I'm dropping by to ensure if everything is covered here. Feel free to let us know if you still need help.
Steve
ali02155
Hi Steve,
I still need help as no suggestion or solution has been given.
Ali
SteveT1
Sorry to hear that. Are you using the provided charging cable? Are the cables seated properly?
If possible, please share a clip of this so we can check this further.
Steve
SteveT1
Jumping in to check if you've seen my response. If you have other questions and concerns. Feel free to let me know.
Steve
ali02155
Hi Steve - did you also see @ruralgreg message? Do you have any real suggestions?
Yes I am using the cable it came with and yes it is working, obviously because it is charging. However it takes 10 hours to charge and that is ten hours of the noise every 30 seconds, please help.
Sorry for the long wait we are always busy and unfortunately cannot get to all threads quickly. In this case, have y'all made sure that you are using the correct charging cables? Have you done all other troubleshooting steps like restarts, factory resets, checking the physical status of the device and cables?
ruralgreg
Would we still be asking if those things worked?  Shoulda went with Ring.
@ruralgreg
I apologize those steps didn't work. As these forums are not a place to get direct support from Google, as this is a Community Forum, I suggest you contact Support for further assistance.
ali02155
Hi all,
Just wanted to share that I have submitted a warranty claim on this which is what you have to do to get service (I have also tried all of the above steps several times). Going through warranty is a painstaking process where a random number will try to call you at a random time and if you miss it they will try to call you again maybe a week later. This went on for several weeks until I finally got someone on the phone who was completely unresponsive and said they had never heard of my issue and didn’t know how to troubleshoot. I now charge the doorbell in the basement or leave the house for several hours while it charges.
best,
ali
2/2 of specialists bailing 👍🏻👍🏻
If still need help I figured it out myself! These people don’t no their heads from their arces
Pachee
Help
janthadeus
Hi Pachee,
What's up? Can you tell us more about what’s going on? We’d love to help.
janthadeus
Checking in to see if you still need help with this. In case there are any follow-up questions or comments. Please let me know if you need further assistance.
janthadeus
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
I have two cameras and both are sporadically on even though they are connected to Wi-Fi. I have one also constantly plugged in but it still will not turn on occasionally.
also if not docked while charging, it will beep every 30 seconds. Overall I barely use these cameras and they are mostly decorative at this point.
janthadeus
Hey Ggalvan1,
I’m sorry to hear that. No worries, let’s get this sorted — a few questions: what types of Nest cameras do you have? When did the issue start? How far are your Nest cameras from the router? Are your cameras paired to a 5 GHz or 2.4 GHz WiFi frequency? Are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the camera? Also, are there other devices connected to the same WiFi where the camera is connected to?
Give these steps a try:
  1. Restart your cameras. Unplug them from the power outlet, wait for 60 seconds then plug them back in.
  2. Restart your router. Unplug it from the power outlet, wait for 1 to 2 minutes then plug it back in.
  3. Move your cameras close to the router within 3 to 5 feet or next to it to check if you’ll have a better view of the live feed.
Let me know how it goes.
janthadeus
Still same issue.  You guys are useless.  This camera continues to make noise while charging.  Thankfully, it’s my in-laws so I don’t have to deal with the noise.  I’m just glad I went with Ring for our home.
janthadeus
It's me again. I want to make sure you're all good — how did the steps go?
Just checking in to see how the conversation is going, as there's been a lapse in activity on this thread.
Merka1990
Hi
ruralgreg
Same problem here.   Makes a da-da-dup sound while charging.  Could one of you specialist answer instead of just dropping in to check?  Is there a way you shut the doorbell off while charging?  I’ve noticed in the app it will show as charging and then jump to “remount doorbell” while making this noise.
Struthers91m
Yes can we get real help here rather then you badge seeking google blokes. About to throw this think across the room and return it 😡😡😡
ruralgreg
One of you “Google geniuses” answer the dang question?
Ggalvan1
I’m experiencing the same problem.
jordaneisel
Spouse and I just switched which brick we're using for the charging cord and it stopped beeping! Do this! I guessed it might be the base because of this google answer:
" Get a full charge in approximately 5 hours with a 7.5W charger (not included), and then reinstall it outside."
Hey all,
If you're still experiencing this, I would suggest you try to factory reset your device, which you can learn more about here. Please let us know if you need further assistance, if that doesn't do the trick.
