12-27-2023 09:52 AM
Our Floodlight is installed from a roof and the motion sensor is pointed out opposite the wall, which is adjacent to the mount. Because of where the cable attaches to the camera, the cable attachment and speaker are prone to water. I realize it’s water resistant but if the cable were maybe 4 inches longer, then I would spin the camera more and the speaker and cable attachment would be much more protected. Does a separate cable extension exist, or any other recommendations exist here? Thank you.
01-01-2024 02:55 PM
Hi iamtedking,
Thanks for visiting the Google Nest Community. I’d be happy to help you with your question about the Nest Cam with Floodlight.
While there isn’t an available extension cable for the device, I’d suggest contacting a Nest Pro installer in your area for help with installing the floodlight.
Reach out if you have any other questions.
All the best,
Lance
