08-28-2022 09:32 PM
I have spent in total 1400 to have electrician run the correct cabling, install the camera, and on the camera itself yet it does not connect. I have contacted support multiple times but the only possible reason it may be giving me the error code is because of the IOS update not being compatible and that a ticket has been sent to higher. So now, I’m basically left with expensive outdoor decor. I have restarted, added to new household, moved the router, used to different iPhones, an iPad, and an android yet none of them have worked. The thing is wired and mounted so it’s not easy to just replace at this point. Would really like any tips or help on this since we have thrived that have been breaking into cars and walking in our backyard. The floodlights do come on with movement, but it’s pretty useless if i can’t have video footage or it added in the app.
09-01-2022 09:35 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I'm terribly sorry to hear that you're having these troubles. I understand how upsetting this could be, but I'm happy to assist you with this obstacle. I would suggest that because you have been working with Support, you should try to stay in contact with them on this case. I cannot think of an additional troubleshooting step to take besides checking to see if your iOS update is available or not. Factory Reset is also a choice, if you haven't done that yet. You can learn how here.
09-04-2022 09:33 AM
I also wasted hours trying to connect to Google home using my android pixel 6 phone. I then tried my wife's apple phone and it connected with no problem. Clearly this is a software glitch which Google need to sort out.
09-04-2022 09:41 AM
It seems that Google has problems getting its own Google Pixel phone to work with its own Google Nest application:
https://www.googlenestcommunity.com/t5/Blog/Heads-Up-Device-Activation/ba-p/176077
09-06-2022 05:46 PM
Thanks for your help here, Brad and MplsCustomer.
We appreciate your efforts and I know how you feel about this. No worries, we'll check this out. What's the status light of your camera? How far is the camera from the router? Also, what WiFi frequency band do you try to connect to (2.4 GHz or 5 GHz)?
Give these steps a try:
Let us know how it goes.
09-09-2022 09:51 PM
I appreciate the help, JT.
Archie
09-12-2022 03:21 PM
Archie
