12-27-2021 11:51 AM
After taking off the doorbell from the base, the small button on top of the doorbell stays inside. After charging it isn't possible to put it back on the base. I think it is because of the small button. It doesn't 'click'. Loose the screws doesn't help. Anybody an idea how get the small button out again?
12-27-2021 12:54 PM
Mine done that and I had to return it for exchange.
12-29-2021 12:20 PM
Hi Haggis, thanks for your reply. Google is doing very difficult about a replacement.
03-23-2022 10:14 AM
03-28-2022 09:49 AM
Just checking in to see if you still need assistance with this issue. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
03-29-2022 10:13 AM
Hey Folks.
