Google Nest Doorbell Battery Won't Mount onto the Plate
MikeWalshBowser
Google Nest Doorbell Battery won't Mount onto the Plate.
I've had my Doorbell for a couple of months and used it in battery mode with no issues remounting it.
Following charging the device, I was unable to mount it onto the back plate. the device would not click back into place.
On close inspection, I noticed the top small mounting pin which you released with the unlocking pin had not been released and reset following the unmount from the plate and was still within and flush with the device.
My Fix to release the button: I used a sharp blade (penknife) to position my blade under the depressed button. i held the blade horizontally to flick the blade outwards to pull the button out. very little pressure was applied and the button came out. this allowed for the device to be remounted.
Hope this helps a few people out
11 REPLIES 11
RXShorty
Hi @MikeWalshBowser
Thanks for sharing your experience and solution!
It is much appreciated, and glad you got it resolved. 😊
MikeWalshBowser
Thanks, @RXShorty
Thanks for the help, @RXShorty.
Hello MikeWalshBowser,
Thanks for posting in the Google Nest Community forum. I appreciate you sharing the information above that might help the Community members in the future. Please let us know if there's anything else you want to share. Otherwise, I'll be locking this thread after 24 hours.
MikeWalshBowser
I'll just provide a photo of how I did my fix
It's me again! Please feel free to share the photo you mentioned above. I'll just keep this thread open for now.
Hey MikeWalshBowser,
I just want to give you a nudge. Please feel free to post the photo you mentioned.
Hello there,
Hey Jenelyn, I don't seem to have the function to add a photo. can you assist? cheers
Hi MikeWalshBowser,
Please click this link then scroll down to your response and hit reply. Check for the camera icon or click the three horizontal dots to expand the toolbar. From there, you'll be able to reply and share a photo.
Checking in — were you able to try the steps I provided above on how to add a photo in this thread? Please let me know how it goes.
I'm just checking in to make sure that you've seen our response. Please let us know if you have any other questions or concerns, as I'll be locking this thread in 24 hours.
