Google Nest Doorbell (wired) won't reset
clgb83
My internet provider changed my internet name and password.  I cannot get my Google doorbell to factory reset so I can connect it to the new internet name.  Every time I perform the rest ritual (probably 10 times at his point), I briefly get a blinking white light and then the light goes solid green.  I removed the doorbell from Google Home prior to attempting the reset.  I have attempted the reset with the doorbell connected to power and with it disconnected.
@clgb83
That sounds like you are only getting a Restart. Are you pressing the reset button for at least 12 seconds as documented here?
https://support.google.com/googlenest/answer/9252162
I have pressed it for as long as 30 seconds with the same result.
@clgb83
You could try contacting Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
