12-08-2022 04:27 AM
Can you use the 2nd gen door bell without a chime ? Do you just hard wire it directly and use Google hub and speakers to announce that someone has pushed the button?
Thanks
12-08-2022 08:52 AM - edited 12-08-2022 08:52 AM
I believe you can hardwire the 2nd Gen Google Nest Doorbell to your doorbell wires connected to your doorbell transformer and turn off the "Indoor chime" option and turn on the "Visitor announcements" option to get visitor announcements on your Nest Minis, Nest Hubs, and Nest speakers.
(We're doing that with our older Nest Hello doorbells because the internal battery on all three has failed, causing them to go offline if they attempt to ring the indoor chime.)
12-09-2022 04:33 AM
Thanks very much
12-10-2022 08:41 PM
Did you have any luck? I have no existing doorbell and just want to run wiring for the Doorbell wired (2nd generation) and then use the phone and Google audio speaker for the notification. Need to know if it works with no chime. I see the instructions start asking about wiring for previous chimes
12-13-2022 11:31 AM
Sorry to hear you're experiencing this, as I can imagine it has been an inconvenience. I would love to look into this further for you. You can learn how to install the doorbell here. You should be using the equipment that comes with the doorbell, which would include the Chime Puck. The link I sent has additional troubleshooting you can look through. Please let me know if you need further assistance.
12-13-2022 11:48 AM
12-13-2022 12:09 PM
I am unaware of such a diagram, so the user can look over the available information that is in the help center.
12-13-2022 12:14 PM
Since you are a Google Nest Community Specialist and since several customers have asked for this, can't you ask Google Nest staff to provide instructions and diagrams for installing the 2nd Gen Google Nest Doorbell without a chime?
12-18-2022 06:06 PM
Checking in should you still have further questions here. Let us know by replying to this thread.
I appreciate the help here, MplsCustomer and Brad.
12-14-2022 09:02 AM
If there is a diagram to share, we will share it here. At this time, there isn't such a diagram that is available to us in the forums. You are welcome to reach out to support to see if this is something they are able to provide.
12-19-2022 07:08 PM
12-19-2022 07:20 PM
Thanks JT,
Got the doorbell installed but now I can't get any of the videos to work. From the doorbell, or either of the 2 wired cameras with floodlights I installed.
01-02-2023 02:46 PM - edited 01-02-2023 02:49 PM
Hello Nyoung,
Thanks for your patience. We appreciate your efforts here. Let’s sort this out — a few questions: what’s the status light of your doorbell? How far is the doorbell from the router? Is it fully charged or plugged into the wall outlet? Also, were there any changes to your WiFi network?
Going over the steps here might help:
Let me know how it goes.
a month ago
I appreciate the help, Brad and JT.
Archie
3 weeks ago
Hello there,
Archie
