Google nest door
Brandonanderson
I have a battery doorbell if I wired it to the doorbell chime will it charge the doorbell?
@Brandonanderson
If you wire your Google Nest Doorbell (Battery) to your existing doorbell wires, which are connected to your chime and transformer, it should charge your doorbell as long as your transformer meets Google Nest's requirements (https://support.google.com/googlenest/answer/9247132?hl=en). However, the charge is a trickle charge and cannot charge the battery at temperatures below freezing (https://support.google.com/googlenest/answer/11830989?hl=en).
MplsCustomer, I appreciate your help.
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue. If you have other questions and concerns, feel free to let me know.
janthadeus
Hi Brandonanderson,
How's it going? Still need our help?
janthadeus
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
