Google nest doorbell battery indoor chime
ssirohi
Recently installed Nest DoorBell battery and nest hub max.
Before that i was using Ring door bells with inside electronic Chime (Ring's chime). So if someone comes on front door and press ring bell, inside chime ring load and clear inside and everyone away
But with Google nest Doorbell Battery didn't find any electronic (non-wired) chime that do do same and bell inside load and clear.
2 REPLIES 2
  • Open the Google Home app
Google Home app
  • At the top right, tap your account.
  • Tap Feedback
and then
  • tap the type of device you'd like to submit feedback for.
  • To display available emails, in the "From:" section, tap the arrow on the right. Select your email address.
  • In the feedback summary, write a brief description of your issue.
  • Be sure to check the box for Screenshot and System logs.
  • To submit feedback, at the top right corner, tap Send
If you need anything else, please let me know.
aatienza
Hey ssirohi,
Chiming in to check if you have additional questions or concerns as we will be locking this thread within 24 hours.
Archie
