02-08-2022 03:45 PM
Hi All.
I'm trying to set up my google nest doorbell (battery). I've plugged the doorbell in to charge as instructed during set up however the light stays white (pulsing) and does not turn blue. I've tried the factory reset - inserting and holding a pin into the back reset hole for 15 seconds and more, however the device won't reset (no white or yellow light appears).
Any ideas on what else I can try?
02-09-2022 04:56 PM
This Google Nest Help page on installing the Google Nest Doorbell (Battery) says, under "Charge the doorbell be for installation":
"Use the included USB cable to fully charge your doorbell for battery-powered installation. Keep it plugged in during setup so that it can connect to the app and the Wi-Fi network."
"The status light will pulse white when your doorbell is charging, and will appear solid white when it’s completely charged."
https://support.google.com/googlenest/answer/10732535?hl=en#zippy=
02-09-2022 04:56 PM
02-14-2022 10:56 PM
Thanks for answering, MplsCustomer.
chester08, do you still need help with this? If yes, how long did you have it connected to a power source to charge? It takes approximately five hours to fully charge the battery of your Nest Hello doorbell (battery) using a compatible 7.5W AC adapter (sold separately).
Melba
02-17-2022 11:19 PM
How's your Nest Doorbell (battery) now? Still need help with it?
Melba
02-19-2022 06:33 AM
Since it's been awhile since this thread was last updated, we'll be locking it if we won't hear back from you again within a day. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Melba
02-21-2022 11:06 AM
Hey Folks.
