12-08-2024 10:48 AM
I’ve added a new router and extender. Deleted the app, power cycled the camera , restarted WiFi….. never connects. Do I need to exchange the camera? Please help!!
12-08-2024 11:40 AM
Google Nest does not make it easy to change Wi-Fi networks. Their first recommendation when getting a new router/modem is to set the network name (SSID) and password to the same values used on your old router/modem. That's what we did a couple of years ago when we got a new router/modem.
https://support.google.com/googlenest/answer/9223711
If you can't do that, then you need to remove your camera from the Google Home app (if you still can) and do a factory reset. See the "factory reset" instructions, not the "restart" instructions:
I think it can be tricky with the floodlight fixture because there are separate settings for the camera and the light.
12-08-2024 01:06 PM
Hi, I never got the camera to connect. I added the router for a stronger signal to set up. There’s nothing to delete from the app
12-08-2024 01:49 PM
Oh, it's a new camera; I thought you just changed your Wi-Fi network.
What does happen when you try to install your camera in the Google Home app?
If it's a brand-new camera and you're following the install instructions (https://support.google.com/googlenest/answer/11003780), and you have good Wi-Fi signal strength at your camera's location, you might consider exchanging the camera, or contacting Support:
