12-28-2021 02:20 PM
i have me nest doorbell hanging from wall as the shell broke and the nest will not fit into the backing screwed into the brick. here is a pic of what i need. please advise where i can buy this part. thank you
03-23-2022 10:58 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
