12-26-2021 08:15 AM
12-26-2021 09:52 AM
Correct. The new battery version is built for the Google Home ecosystem, not the nest app.
12-26-2021 11:05 AM
Yes all my older cameras after some initial delay open in google home which is fine. Question: what happens to my nest aware plus account balance?
12-26-2021 11:08 AM - edited 12-26-2021 11:09 AM
Not sure on that. I presume there's some way to get the new cameras onto your old nest aware account, but as I don't have any of the older cameras, I'm not sure how that's done. I'm using New Aware with the new camera, but I set it up using the Home App from the start. Hopefully someone else that's made this transition will chime in. Sans that, I think you'll have to call google support and ask if you can migrate your Nest Aware subscription (and/or any remaining account balance) to the Home App.
12-26-2021 11:12 AM
Thanks I think I’ll wait till January and hopefully the support will be less spotty
03-22-2022 11:59 AM
Thank you for your feedback on this issue, I fully understand the frustrations of not having your new Nest Cams in the Nest App or available on https://bit.ly/3HtBgJC web app. I can imagine having to use two different apps at the moment is quite daunting, and could lead to frustration.
However, the new Nest cameras and doorbell are exclusive to the Home app because we wanted to create an integrated experience with your speakers and displays. A Nest Aware subscription applies to all of your cameras, speakers, and displays in the same home structure. Thank you for your continued patience, and support. I am more than happy to assist you further with this inquiry if you wish. Please let me know.
04-22-2022 04:28 PM
Hey guys,
Chiming in to check if you have additional questions or concerns as we will be locking this thread within 24 hours.
Let us know so we can assist you right away.
Archie
04-25-2022 08:20 AM
Hey Folks.
04-21-2022 04:02 PM
Chiming in to check if you still need help with this?
Feel free to respond to this thread if you have additional questions or concerns and I'd be glad to answer it for you.
Archie
