09-20-2021 05:13 PM
09-22-2021 08:39 PM
The below link will help define the support option for the issue:
09-30-2021 01:48 PM
Hello Cnow,
Thank you for your patience with us! We've created a case for your issue to send to our support team. Be on the lookout for an email from us in your inbox soon. For reference, your case number is 6-8587000031929.
Kindly,
Ai
11-13-2021 12:42 PM
I have had my doorbell for less than a year. When I removed the doorbell to adjust the wiring the wall mount piece that holds the top part broke. Where can I get a new wall mount?
