NEST Camera Outdoor Replacement Power cord
mcclin47
Hi, the power connector on our nest camera outdoor just died. We have two cameras and I swapped the power connector and was able to power up either camera, so I know it is the power adapter that doesn't work. How can I replace this part? Thanks!
Thank you for your patience. Please fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number.
