02-02-2023 08:40 AM
The Nest battery security cameras for outdoors give me so many headaches when it comes time to charge. I use the cable provided every time, but i always have to push the button on the back to get the unit to play the charging sound or even indicate in the app it is being charged. Even that only works half the time. Is there something with the contacts that need cleaning or the cable or some trick i’m missing?
02-06-2023 10:27 AM
Thank you for your patience, and sorry to hear that you're experiencing this. I know that keeping your Nest devices charged is very important, and I would love to help you out. When it comes to keeping your Nest Doorbell (battery) or Nest Cam (battery) up and running, here are some articles and troubleshooting guides for the best charging practices:
I hope those articles help shed some light on charging and maintaining battery levels of your Nest doorbell or camera. Please let me know if you need further assistance.
02-06-2023 01:46 PM
i will clarify the charging for the devices occurs inside at room temperature and is not related to the issue i’m having.
02-08-2023 10:11 AM
Thank you for the clarification, I appreciate it. It is possible you may have a faulty cord. Do you have another camera you can test the cable on to see if it functions the same? Please let me know.
02-08-2023 01:17 PM
It's replicated the issue on all 3 cameras I have. Unfortunately I only have the 1 cable, and because of the proprietary connection point I haven't been able to try others. It seems to recognize the camera on the app after I hold down the small button on the back of the camera for around 5 seconds if that makes any sense.
02-09-2023 08:14 AM
I would love for you to please fill out this form, and a higher tier of support will be reaching out to you with next steps. Once filled out, please let me know, and you should hear from them soon after.
02-11-2023 07:19 AM
Sent.
02-16-2023 08:32 AM
Thank you for filling out the support form. You should hear from support very soon if you haven't heard from them already. Once they reach out to you, they will be assisting you moving forward with this concern.
02-20-2023 09:44 PM
Thanks for the help here, Brad.
