08-04-2022 08:05 PM
Purchased two nest cam's the middle of July. This morning I turned off the video and I could never get it back on through the app. It would just say "connecting" and just spin. This evening I tried to do a restart...twice. Still the video won't turn back on. The only other solution was to factory reset it. Unfortunately\fortunately that worked, however I lost all of my archive. I don't know if anyone else has had the same issue, but seems like a software fix is in order.
08-07-2022 07:43 PM
Hi Dirge,
I'm sorry to know that you haven't been able to see the live video of your Nest Cam Battery. No worries, we'll figure this out together — please help me with these questions:
Looking forward for your response.
08-08-2022 05:06 AM
Yes, I have a similar problem. New Nest battery camera installed outside on Saturday, dead on Sunday. I had to do a factory reset to get it to install (stuck on update loop). Seemed to go OK. Sunday night it turned off and I cannot get it to turn on. When I try to turn it on, Home app says connecting and then stops. No other messages.
The camera is about 6 feet from the router. The Home app says the battery is 87% and that it has a good connection. Speed test shows 22-25 Mbps to the camera. The status light is off. I have a Nest IQ outdoor and another Nest camera inside working fine.
I don't have an archive yet since it has worked for less than 24 hours. Time for another factory reset?
08-08-2022 07:45 PM
Great troubleshooting so far, RockyGrinder. Let's get this sorted — a few questions:
You can also give these steps a try:
Let me know how it goes.
08-09-2022 10:47 AM
I noticed the issue when I turned the camera off in the app and then tried to turn it back on. It wouldn't come back online. I guess it depends on what "extreme" is. I live in the south and the temps have been in the 90's most days. During the issue the camera felt normal, no abnormal temperature issues.
I did eventually get the camera working, however two resets didn't work and I had to disconnect the camera and go through the re-adoption again. It seems to be working OK now.
08-09-2022 07:09 PM
Sounds good! Thanks for your efforts. I'm glad that it's already up and running. If you have other questions and concerns, feel free to let me know.
08-13-2022 07:55 PM
I have the same problem. Turned off 6 cameras , to conserve battery while doing some yard work and only 4 would turn back on. Home app say connecting for about 12 seconds , then it stops and cameras are still off. Did a reboot, that didn't help, performed a factory reset, that fix it temporarily until I turned the cameras off again to test and now a 2 different cameras won't turn on.
08-15-2022 04:52 PM
Hi Waylay,
I'm sorry to hear that, great troubleshooting so far and thanks for your efforts. let's get this sorted — a few questions: what's the status light of the cameras? What types of cameras do you have? Also, are they fully charged before you set them up?
08-18-2022 05:46 PM
Hey Waylay,
I appreciate the help, JT.
Archie
08-19-2022 07:49 PM
Hey Waylay,
Archie
