Nest Cam Floodlight Mount
Jnong7
Where can I purchase a replacement Floodlight Mount for my Nest Cam?  I did not see it in the accessories site.  Please assist.
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
Just checking to make sure that you filled out the Support form that I sent a few days ago? Please fill that out so that you can be assisted with this Replacement inquiry. If you have, then you can disregard.
Best regars,
Hey Folks.
