Nest Cam IQ Outdoor Faults
DenDen
Is there a known reliability issue with the Cam IQ Outdoor?
I have had 5 of these cameras 4 of them (including 2 replacements from Google) eventually failed (either just dead or unfixable flashing blue light issue).
There is something called 'reasonable expectation' in UK consumer law which means we are not limited by a manufacturer's warranty if something does not work as could be reasonably expected.  Such an expensive security camera should be expected to work far longer than a couple of years.
Anyway Google no help whatsoever outside warranty so I am forced by poor quality to look at other vendors.
