11-07-2021 01:41 PM
Have tried setting up new Nest Cam Indoor device using entering six digit code manually, because QR code was thrown away with box after mounting in first home. Each time I get as far as the page that says 'Choose the last 4 digits of your camera's serial number' - but cannot get any further. Status of the camera is green dosent show any other color cannot add the device to NEST app at all only to google home.
The camera is approx 5 feet from the router and I have no reason the belive that anything is faulty within the wifi system itself.
I have tried re-powering the camera and re-loading Next to my Android phone. Factoring resetting the camera.No progress.
Any suggestions please? I am in the middle of converting my whole home from Alexa to Google so this is pretty disappointing, especially since I am paying for Nest Aware.
Solved! Go to Solution.
11-11-2021 07:41 PM
@Bmarte it didn't sound like there was a solution. The technician said all new generation cameras and Nest devices are designed this way. Going forward everything will be on the Google Home app sadly. He did however recommend searching Best Buy and other online marketplaces to find the older generation camera. I returned my new Nest Camera and found an older generation locally which easily added to the Nest app, so all good now.
11-08-2021 08:15 PM
SAME here....cannot go further. has your one been fixed yet?
11-08-2021 09:03 PM
Nope no fix, no response from Nest or Google support.
11-10-2021 05:19 PM
I am having same issue when trying to set up Nest Thermostat in Google Home App
11-10-2021 05:24 PM
I'm trying to set up a nest thermostat using the Google home app and also cannot see any place to enter last 4 digits of serial number on screen.
11-10-2021 05:46 PM
Just off the phone with Google Support and the new generation of Nest Cameras are ONLY supported by the Google Home app going forward. No current generation Nest cameras are supported by the Nest App.
11-11-2021 09:44 AM
@jh86 thanks for sharing this. I guess I have to contact support as well, because if you pay for Nest Aware I should be getting the same coverage on that camera seeing as it was purchased this year. Otherwise, it is a mispromotion on their end.
11-11-2021 10:29 AM
If all of your devices are connected to the same account/email, then your Nest Aware should be covering all of them. Regardless if they are in the Nest App or the Google Home App. Now, depending on your Nest Aware plan, will depend on events. When it comes to the Serial Number, you should still have the Serial Number on the back of your devices, or under the mounting hardware. Please let me know if you need further assistance.
11-11-2021 10:51 AM
Hi Brad,
Currently I am only able to view some devices on Nest app and some devices on Google App. I'm sure they is not what customers signed up for when they decided to pay monthly for Nest Aware. This is absolutely unintuitive to use these products and pay for this service.
If you would like further information please let me know.
11-11-2021 11:53 AM
Additionally the issue that is persistent and common to all members that are replying to this forum is the functionality that does not seem to work with Nest as a partnering service. If you could opine on a solution there that would be great, as we all appear stuck on a particular step in the new product adding process.
Thanks looking forward to a response!
11-11-2021 07:41 PM
11-11-2021 08:52 PM
Thank you for providing clarity on this, appreciate letting the collective know. Will need to reconsidering using Google/Nest as my smart home platform if these issues persist.
11-29-2021 02:41 PM
Hey Folks.
11-24-2021 10:29 AM
Thank you for your feedback on this issue, I fully understand the frustrations of not having your new Nest Cams in the Nest App. I can imagine having to use two different apps at the moment is quite daunting, and could lead to frustration.
However, the new Nest cameras and doorbell are exclusive to the Home app because we wanted to create an integrated experience with your speakers and displays. A Nest Aware subscription applies to all of your cameras, speakers, and displays in the same home structure. Thank you for your continued patience, and support. I am more than happy to assist you further with this inquiry if you wish. Please let me know.
11-11-2021 08:13 AM
Same here. Can’t continue setup as a result. Must be a firmware problem.
11-26-2021 03:52 PM
And add another to list, same issue. Just got it today and that's where it is stuck. Never shows a list to choose last four of serial number from.
11-28-2021 12:16 PM
We moved into a home with a nest ring and it is also stuck at the point of listing serial numbers. We have tried the google home app but it tells us to use the nest app. Stuck and confused!
11-29-2021 11:42 AM
11-29-2021 11:45 AM
I was able to add the hello once I did a factory reset. Thanks for asking!
