Nest Cam battery performance plummeting
Jaketown
Two Nest Cam (battery) devices purchased together as a set and installed outdoors at same location equidistant from router. Both have nearly identical low usage. One will charge fully within 10-12 hours indoors and the battery life has until recently extended to six or so weeks (device #1). The other takes 24+ hours to charge fully and the battery life rapidly diminishes within a few days (device #2). Charged device #2 Sunday/Monday and replaced it in its mount Tuesday morning, 24 hours later it is at 25% with no triggered events. Charged device #1 yesterday/Tuesday and 12 hours later it is at 68%. It has always taken device #2 longer to reach a full charge. Performance has deteriorated more quickly for device #2, but the rate of decline for both is getting more rapid - particularly for #2. Considering the cost for the pair of Cams, this declining performance is alarming.
@Jaketown
What happens if you swap charging cords? Is the cord fully seated in the bottom of the camera?
Google Nest says it should take "approximately 5 hours to fully charge the battery" (https://support.google.com/googlenest/answer/11052520). Perhaps your camera is defective and you should try contacting Support for a replacement:
(We've had a battery camera for 19 months, plugged in with the optional power cable, and it's "Live" and charged at all times.)
Jaketown
Contacts are clean, cord is fine. I was able to get support for the devices, which involved factory reset, remove devices  from Home App, full charge, reinstall. Working properly again!
janthadeus
Hey Jaketown,
Happy to hear that! I appreciate all your efforts here. It looks like we can consider this one complete, so I will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Thanks for your help, MplsCustomer!
