02-17-2023 03:03 PM
I've uninstalled from home and unplugged many times.
But the white light comes on briefly and then turns green.
Setup in Home continually fails, just tells me that something went wrong.
I did have the camera working for a few days but changed my wifi password and uninstalled.
Any suggestions???
02-17-2023 03:11 PM
If you changed your Wi-Fi password, then, in addition to removing your camera from the Google Home app, you may need to do a manual "factory reset". (Just today, another customer in this forum had to do that to get their battery camera connected to a new Wi-Fi network: https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Battery-Nest-Cam-getting-it-to-connect-....) The manual "factory reset" instructions call for pressing the reset pin/button for at least 12 seconds, until the status light blinks yellow 4 times after 10 seconds and you hear a countdown tone, and then at 12 seconds the status light is a steady solid yellow and you hear a confirmation tone:
https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-cam-wired
02-17-2023 03:23 PM
2nd gen doesn’t have a reset button, does it? I see nothing have heard that the unplugging is the reset.
02-17-2023 04:50 PM
See the other thread and the instructions in my links. The instructions differentiate between a restart and a factory reset for each camera.
02-17-2023 05:49 PM
as stated before, unplug doesn’t seem to work. Or did I miss something?
02-17-2023 05:54 PM
Unplugging is just a simple reboot. See the link for factory reset instructions, which I also summarized earlier.
02-17-2023 06:00 PM
I’ve read numerous times and cannot find the mysterious reset button.
02-17-2023 07:02 PM
It is small and can be hard to find,
"Locate the reset hole on the bottom of the camera head. It’s between the power cord and the camera neck. Insert a paper clip, thumbtack or similar into the hole. Press and hold down..."
02-17-2023 07:44 PM
Bingo! Sorry, didn’t know the base could twist out of the way to reveal the hidden reset. Worked like a charm.
02-21-2023 02:46 PM
Woohoo, we’re glad to hear that resetting your camera works! To make sure, do you have other questions or concerns?
Thanks for the help here, MplsCustomer.
02-24-2023 06:41 PM
Hello there,
I appreciate the help, JT.
Archie
