08-14-2023 08:54 PM
What's the operating temperature for the Nest Camera 5 or 10M power cable?
https://store.google.com/us/product/nest_cam_weatherproof_cable?hl=en-US
Thanks!
08-18-2023 11:57 PM
Hi RavenManiac,
Thanks for reaching out here in the Community. The batteries in Nest Cam (battery) and Nest Doorbell (battery) have the following minimum temperature requirements:
At temperatures between -4°F (-20°C) and 32°F (0°C), the battery can still power your device, but it won’t charge. It may also drain more quickly than usual. At temperatures close to -4°F (-20°C), your battery may have less than half the life that it has in warm weather. Hit this link for more information and let us know if you have more questions in mind.
08-19-2023 08:41 AM
No, I meant the Nest Battery POWER adapter that plugs into an outlet. I have several in my attic powering various Nest Battery Cams positioned on the exterior of my house.
08-21-2023 02:42 PM
I'm sorry for the confusion. The Nest Weatherproof cable is IP65, which is weather-resistant and should work regardless of the temperature as long as it has not been damaged or disconnected from the power outlet.
Let me know if you have additional questions.
Edmond
