Nest Door Bell Peeling and Flaking after 20 Months
JoeG4
$250 spent on doorbell and another $180 on electrician upgrading the transformer and doorbell is dead.  You would think a product that costs this much would last at least a couple of years.  Looks like I will check out Ring.
Viixy
Dont I moved from Ring as it basically stopped working after splitting. My Nest doorbell looks just the same as yours now and refuses to connect to my wifi.
JoeG4
So I guess the best solution is to go with an old mechanical one or wait until Google stands behind the products they sell.
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
Hey Folks.
