Nest Door bell turn off
FARMAN
My nest doorbell goes offline and this issue started in the past few days. any idea why its behaving this way?
EmersonB
@FARMAN It's us again. I'm bumping up this thread to ensure that everything is covered here. Let's see what other steps that we can do here. To confirm, how far is the camera from the router? Are you getting any error messages? Are there devices or appliances (such as baby monitors, microwaves, cordless phones, etc.) near the camera? Aside from restarting your Nest Camera, you may try giving these steps a try:
  • Restart your mobile phone and WiFi router.
  • In case you are still having the same issue, try resetting your Nest Camera to the factory default. Remember that after the reset all of your recorded events will be deleted as well.
  • Remove and re-add it to your Nest app or Google Home app.
Let us know how it goes.
I appreciate the help, Brad.
EmersonB
Hello FARMAN,
