03-12-2023 12:48 AM
A few weeks ago our Nest Battery Doorbell stopped ringing on our Home or mini devices. We do receive phone notifications, though.
- Indoor Chime is greyed out (although after a reboot it was available but didn't fix the issue and then it turned off overnight and is greyed out again)
- push Notifications is on
- away settings not enabled
- reboot done
- reset to factory settings
- current temp is 7 degree Celsius/ 45F
- battery fully charged
Problem persists.
Please help.
03-12-2023 06:58 AM
Is your battery doorbell NOT wired and running solely on battery power? Based on other posts in this forum, Google Nest seems to grey out and disable the "Indoor chime" option if the battery doorbell is NOT wired, which makes sense because it's not possible to ring an indoor wired doorbell chime with an unwired doorbell. There's just no documentation anywhere that Google Nest disables the "Indoor chime" option.
Is your "Visitor announcements" option still turned on in your doorbell's Settings? If it is and "visitor announcements" are still not working, you may want to contact Support (https://support.google.com/googlenest/gethelp). I've seen a few other posts from customers whose "visitor announcements" inexplicably quit working for their battery doorbell.
03-17-2023 07:08 AM
Hi LizEvans,
Thanks for posting here in the Community. I appreciate you sharing what you've done with your concern. To confirm, have you checked if your visitor announcements is enabled?
Give these steps a try:
03-17-2023 10:36 AM
Thank you. I had tried that as one of my initial steps but it didn't work. However, I did reset both the doorbell and the Home device to original factory settings and that did work.
03-17-2023 11:23 AM
Hello LizEvans,
I appreciate you getting back to us and I'm glad that it's resolved now. We’ll consider this one complete so let us know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
